0 Members and 1 Guest are viewing this topic. Read 5389 times.
so you are probably going to loose that 9dbs for your typical distance.....
I'm a big fan of Rethm Audio for this type of setup..:
Ed's Horn one or two are tempting but I am hoping for monitor size rather than floor standers.....
Quoteso you are probably going to loose that 9dbs for your typical distance..... Not quite that simple. Most specs are taken in an anechoic room, so you can expect a few dB more spl in real room most of the time. You are listening to a stereo pair so you also get a 3dB gain here. Most folks are going to loose only 3 or so dB for distance. In the end you can take an anechoic reading as it stands for good in room response and maybe even add 2 or 3 dB.
