Stupid question about active crossovers...
0 Members and 1 Guest are viewing this topic. Read 1227 times.
massappeal85
« on: 21 Jun 2003, 01:32 am »
If I actively crossed-over my subwoofers from my monitors, I would then have a volume control for the subs, and one for the monitors right?
So, do people who bi-amp their system this way have to fiddle with each volume control everytime they have to turn their music up/down? Or is there some way to get around this, i.e. is a master volume control used somewhere before, within the active crossover?
nathanm
« Reply #1 on: 21 Jun 2003, 01:44 am »
The XO trims control the woofer\tweeter balance but the preamp volume controls the global volume as usual, as it is before the XO.
doug s.
  • makin' music
« Reply #2 on: 21 Jun 2003, 02:08 am »
nate is correct - the x-over goes between the preamp & the amps.  best, & ultimately easiest, most flexible way to subwoof, imo...  the only time i futz w/my x-overs' controls, is when i change monitors, or amps.  i pull out my pink noise generator/spectrum analyzer for this purpose.  these are cheap & plentiful, used, on ebay...
doug s.
massappeal85
« Reply #3 on: 22 Jun 2003, 01:19 am »
Oh geez, I didn't know the pre-amp went BEFORE the crossover.
As usual, thanks for the answer!
