0 Members and 1 Guest are viewing this topic. Read 10971 times.
Will the vibration coming from the Maestro sub be transferred to the speaker on top and causing coloration or disortion ? Most people do is to isolating their equipment from vibrating partners with cones, or with other dampering mechanizm ?
Hi Mike,Seeing what budyog has done and having a pair of Maestros, I will want to pull out the 2ch pre and try stereo subs.I will try this with a pair of Allison AL-125s, a 3-way system with 2- 6” woofers in a push pull arraignment, -3db = 48Hz; -6db = 38Hz. I believe the 2nd woofer comes in at around 100HZ on down with a half section (12db/octave?) crossover. The second woofer is reversed to lower harmonic distortion. I realize I’ll loose some of the benefits of the 2nd woofer, but…These are about 30 in tall x 11 x11 so copying Budyog’s setup has crossed my mind. i.e.: speakers on top of subs. I’m interested in your recommendation for Xover F and is the 6db slope of your rca filters steep enough?I noticed you also have balanced filters with a 12db slope. Can the xlrs on those be used with xlr to rca adapt, or would you loose the extra slope?Also, would there be any advantage to spacing the subs wider than the main speakers? Or is that back to trial and error? I’m looking at a 25 ft wall with the mains about 10 to 12 feet apart.Thanks,Joe
