FryKleaner Pro Kit part question
0 Members and 1 Guest are viewing this topic. Read 1685 times.
poseidonsvoice
    • 2 channel/7 channel setup
« on: 26 Sep 2006, 02:24 pm »
Jim,
Ordering parts for this kit, and I noticed that the part 511-2N3904 is now unavailable/obsolete due to the new ROHS restrictions  :nono:. Is the transistor with the part number 512-2N3904TA an acceptable alternative from Mouser  aa?.
Do you recommend changing C4 to 100uf for extended bandwidth?
Thanks  :thumb:,
Anand.
« Last Edit: 26 Sep 2006, 02:40 pm by poseidonsvoice »
hagtech
Re: FryKleaner Pro Kit part question
« Reply #1 on: 26 Sep 2006, 05:36 pm »
You can use any 2N3904 they have in stock.  Damn part numbers change all the time.  Best to leave C4 as-is, otherwise a bit of 120Hz ripple gets into the high gain section.
jh
poseidonsvoice
« Reply #2 on: 26 Sep 2006, 06:24 pm »
Jim,
Thanks for the quick reply. An excellent kit, does a world of good for us tubeophiles who need to break in stuff without using up too much of a tube's life. If I had to vote for Accessory of the year, it would be the FryKleaner Pro kit  :D
I'll be ordering it today or tomorrow, just as soon as I figure out if I need anything else from Mouser for my other projects...
Look for an upcoming review once I'm done breaking in my components...
Best regards,
Anand.
