My room size is 15feet x 11feet 8inches x 8feet. I have the hyperions(back of bass speaker)2feet from the back wall which is a solid stone wall and 2feet 6inches from side walls,one of these being a solid stone outside wall the other a stud dividing wall.My amplifier is a modern British design pre and power transistor,never been a valve fan, power amp over 200watts per channel,this combination only purchased this year but I have used this firm(AVI) for last 12 years.The speakers are angled in very slightly around 10 degrees. All this leads to a very smooth sound from around 30/35 hertz to as higher than I can hear. The bass is excellent firm,defined notes no problems there at all.I also use an equivalent of Isonodes to sepatate two units-this really makes a difference.Room furnishings are soft i.e. room carpeted settees heavy curtains.Speakers are also bi-wired a proper cable link to other speaker connection.I hope above gives you an idea of room etc.I found the 938s pretty easy to set up and positioning not over critical,I think the soft furnishings help and "scattered" book and CD shelves also help break up possible standing waves.
