0 Members and 1 Guest are viewing this topic. Read 3757 times.
VK6200 has lot a of 'oomph' , and is wonderful SS/neutral Amp with ample current/power, but is a bit sterile (maybe its me but most of BAT's SS Amps are imho)...if you mate it with a tube pre then you will enjoy it.Cheers,Kishore
Steve,Everybody is their own movie critic, but my favorite 5 channel amp is the Cal Audio CL2500. Very robust power and musical. Being a neutral sounding amp, believe it would blend well with your HT3's. May be hard to find as Cal is no longer in business. Every once in a while one pops up on audiogon though.Good luck in your search.Regards,Jeff
I don't have any experience with the amp mentioned, but I can say that the VK-600SE is definitely not sterile sounding. I am fine with saying on the record it is one the best two solid state amps I have owned, auditioned, or heard in a familiar system (the other is the DartZeel). How much of that sound is found in the VK6200? I have no idea.You can always ask BAT, but that is obviously a biased opinion.Are you getting the VK6200 new or used? Anyway to audition it or buy it used so you can try it in your system and let your ears decide?
Steve,Did you see this on Audiogon:http://cls.audiogon.com/cgi-bin/cls.pl?ampsmult&1163900309I am not affiliated with the seller in any way.George
Steve,I have a 3-channel VK6200 and am driving, actually connecting them this week, to 3 HT2s.I have driven other speakers with this amp and can report that it is effortless, dynamic, neutral and nuanced.It is dead quiet. No noise with no input.There are certainly other fine amps out there but at this level it really is a matter of taste.I've spent time with BAT tube products and prefer their SS.As you know it's built like the proverbial brick outhouse and most all of that weight comes from the monoblocksand not from the chassis.The only issue I have experienced with the BAT was due to its size.It's 24" in length and can present a problem when trying to fit it in a regular rackBAT as a company, is a pleasure to deal with and are real people.I'm pretty sure you will love it how it sounds with the HT3s.Remember, lift with you legs
