DCX 2496.How do I...?
lito
« on: 23 Sep 2006, 08:43 pm »
How do I remove the ribbon connector. Do I just pull it out using the wires.I am afraid of damaging it. I am interested in removing the one end closest to the input. I am having noise and bad connection.TIA
Lito
warnerwh
Re: DCX 2496.How do I...?
« Reply #1 on: 23 Sep 2006, 11:14 pm »
Try to grab the plastic part at the end of the connection. When reinstalling be sure to push firmly on both ends to make sure it's all the way down. Sometimes ribbon cables can feel like they're down and they're not.
Sometimes ribbon cables will go on both ways so be sure to mark one end so you know which way it came off.
