0 Members and 1 Guest are viewing this topic. Read 6546 times.
There is a practical limit to the smallest size of an open baffle speaker, if it is expected to reproduce a balanced full range sound spectrum. The PMT1 represents this case. The speaker might be used for a stereo system in a small room or for side and rear speakers in an audio surround setup.
Speaking of my Joint Chiefs, I do have a pair of mini-JC baffles that I haven't even tried yet. They're not much bigger than a typical computer speaker, but they are equivalent to an 18" wide flat baffle in the farfield. I designed them for surround use near my ceiling corners, but they'd probably do great at the edge of a desk. I just haven't decided which driver to use and I don't want to mar the wood until I'm sure.
OBs work great at the desktop and I used some that way for over a year. If you have a CRT monitor then magnetic shielding is important unless you can set the speakers well away, but then you really need to roll your chair back for better listening.As far as I'm concerned virtually all OBs need bass augmentation, and a sub under the desk works fine. I've used desktop OB's in a number of ways that you can get extra effective baffle for free. Also, being in the nearfield gives you free effective width as well, because OBs have more bass in the nearfield due to 2 factors. 1. The rear wave has travelled significantly farther as a % of the front wave travel distance, so the rear is lower in magnitude and has less affect. 2. The separation distance (rear of driver to your ears minus front to ears) is greater due to the angles (except for U-baffles).How do you get free baffle? One simple method is using your monitor as part of the baffle. Small baffles attached to the sides of your monitor is the easiest example. Add an angled wing to the sides, and get surprising extension. Another way to get free baffle is, if your desk has open space in front, set the speaker near the edge. Then much of the rear wave will expand down below your desktop. This can work even better than the floor, because you get boundary reinforcement for the front wave, but not for the rear wave.Small drivers are the way to go for the desktop for size reasons and I find their sound gels better in a short distance. 2 drivers I've used for desktop OBs that work really well are the Fostex FE127E and Adire's AV3. Both are magnetically shielded. Without a sub, I'd go with the AV3 as its higher Q makes for fuller sound on the same size baffle, but it isn't as efficient, so it depends how loud you want to listen.Another benefit of using small drivers is the test baffles. You can literally make test baffles in a couple of minutes with cardboard, tape and a knife. If you want to spend a couple of bucks, get some of that foam filled posterboard like architects use to build models, because it's more rigid than cardboard. Then you can try some different things to see what you like best, and the final form wood baffle will sound even better.Speaking of my Joint Chiefs, I do have a pair of mini-JC baffles that I haven't even tried yet. They're not much bigger than a typical computer speaker, but they are equivalent to an 18" wide flat baffle in the farfield. I designed them for surround use near my ceiling corners, but they'd probably do great at the edge of a desk. I just haven't decided which driver to use and I don't want to mar the wood until I'm sure.
So how are the dimensions for the wings and baffle caluclated exactly?
