biamping the ra8
Berndt
biamping the ra8
« on: 6 Sep 2006, 02:18 am »
Al, is it just an extra set of terminals and the wiring?
A little bird told me set amps and high sensitivity tweaters are something special, I realize this would be out of the realm of biamping but I know you have thoughts about this.
Thanks, Bill
Ps, I love the RAW fleece.
RAW
Re: biamping the ra8
« Reply #1 on: 6 Sep 2006, 06:19 am »
Bill
Yes you can do the biamp if you like.
If so use  the biamp use terminal posts not the cups, well you can use the cups but you will use 4 and having 2 cups on the back may look funny :o
Terminals would be the best.
And the comments to some and others do not find biamping needed.
All in personal taste.
