in search of wall mounts for emerald onwalls...
0 Members and 1 Guest are viewing this topic. Read 1259 times.
enigma7
« on: 1 Sep 2006, 12:28 am »
i know they are designed to be hung flush against the wall, however i'd like to use mounts to direct them in a slight angle (they will be hung very close to the wall). i've researched speaker mounts however i am unsure which will support the emerald's keyhole configuration. anyone have any recommendations?
Mike Dzurko
Re: in search of wall mounts for emerald onwalls...
« Reply #1 on: 3 Sep 2006, 11:25 pm »
Wish I had ideas for you . . .  you need something that you can attach the existing brackets to if possible. If not, you can probably just attach directly to the rear of the enclosure.
