0 Members and 1 Guest are viewing this topic. Read 16154 times.
John & George.Thanks for posting the pictures.You should post the one showing the beautiful MLS cabinet too.Wood is African Ebony.Dave
That's a "wife friendly" system! Are you also bi-amping the RM40s?
Can current owners get a sticky w/ detailed instructions & pictures on how to remove the crossover and reinstall the OXO?Obviously w/ the pots and crossover external something has to change internally w/ the speaker.Thanks.
And that top woofer on the RM-40's is giving me more grief.Dave
This may be a dumb question but it is a point on which I guess I am unclear. As I understand it, in passive bi-amping the incoming signal is split, typically through a Y connector and fed to two amplifiers. One powers the bass spectrum while the other powers treble with the internal crossover separating the two. What is gained (if anything) by using an electronic crossover to split the incoming signal ahead of the amplifiers? It would seem that this adds equipment into the chain to split the signal that the internal crossover would later split anyway. Is an electronic crossover only appropriate for active bi-amping or am I getting tied up with semantics (or something)?
JohnThis is why you make the big bucks: Why don't you find out for us whether or not any of the most popular digital xo's can simultaneously provide the xo function & a 1st-order upward tilt @ 5 kHz eq, that is apparently absolutely positively mandatory for the CDW to properly function. It certainly appears the whole subject of full active eq for any CDW ribbon is a moot point till the eq & xo are both accomplished. Dr. Kevolsky certainly knows the answer to this conundrum. I suppose, if necessary, the eq & xo functions could possibly be performed in the digital domain in two different & seperate components daisy-chained in series (one eq, one xo), though that appears to be not ideal for several obvious reasons: clutter, cost, expense, cost, potential negative effect on transparency.
