0 Members and 1 Guest are viewing this topic. Read 16772 times.
Satfrat,Did you get them from a local dealer or are you going Mfg. direct? I can ask Luis about the upgrading to 5 channels if you like.
There is one negative tho that stood out, the power cord is captive. Luis says Butler is experimenting with IEC PC`s
I am currently shopping for an amp replacement. I am considering AVA 550ex, 2A3/EL34/805/300B tube amps, and bulter audio 2250 and 5150 or used krell FPB 300 or 400c/cx.JohnB: could you elaborate on the differences b/w bulter 5150 and ava 350ex?Also could someone tell me how much are 5150 and 2250? Where can I find the local dealer info? Thanks.
QuoteThat's weird, if they are the same unit minus 2 channels, how is it I have an aftermarket Sahuaro ampthrilla PC attached to my 5150? This cord really pushed the performance, which was already stellar, up several notches. Get that mod done! Thanks for the info AGAIN John, I called Luis and it was a misunderstanding. He was referring to replacing the IEC terminal itself! And chances are I`ll be doing that as I do like the Acme cryoed silver terminal. He was also referring to the company looking into offering an after market power cord upgrade wth their amps. Guess it was just one of those crazy misunerstandings that can occur over the phone, heh? Luis is also having the feet removed an sent separately as I`ll be using cones. Looks like I`ll have to be scoping out some PC`s. Regards, Robin
Satfrat,Wow! You really get a rig of amp/pre combo that can do excellent multichannel/Stereo now! Not to mentioned it is under $5.5k. Could you tell me where did you get your 3150 from? I look forward to reading your review on this combo soon. Thanks,-Howard
John B, hi, gotta question for ya. After seeing Wayne Wanaanen`s new tube momo amps from Radii Audio, I noticed all the tubes had Herbie`s Damping Instruments on them. And thoughts on this, is it anything you have considered doing for your 5150? I went ahead and ordered 6 Hal-o 27 rings for my 2 3150`s as I`ll be opening the unit up anyways for the IEC upgrade and might as well throw them on. I think it was Enjoy the Music that hada good review on this tweak, especially the tubes on the amps. BTW, my amps should be competed and shipped from the factory any day now. Regards, Robin
