Exodus 61 Bookshelf - Amazing as a WAF-friendly 2-channel HT Option
0 Members and 1 Guest are viewing this topic. Read 2164 times.
kfr01
I wrote a review of the Exodus 61 Bookshelf speakers some time back.  I was so impressed, I built the large Exodus 2641 towers for my 2-channel listening.
Link to the Exodus kit here:
http://www.diycable.com/main/product_info.php?cPath=24_92&products_id=539
Until recently, I had never listened to the Exodus 61s with movies.
The Exodus 61s sat in my basement for the longest time after I built the 2641 towers.  However, we recently moved to a new home, and they've been moved to family room HT duty.  In the past I've always used full surround sound solutions for HT.  I ran into a couple problems when thinking about this new family room HT.  First, my wife wanted the TV in the corner.  Second, the home is very old; fishing new wire lengths through the walls is not something I wanted to try.  Third, my old surround speakers went with the buyers of our previous home.  :-)
Anyway.  I set up the Exodus 61 bookselves in the family "ht" room.  I turned off the subwoofer out, set the fronts to "large," routed the LFE to the fronts, and turned off the center and surround channels.  Everything is being routed through the Exodus 61s.  We watched Sahara last night --- I was very impressed with the capabilities of the Exodus 61 bookshelves:
They imaged like a center channel was in the room.  They handled the bass duties as well as many <$500 subwoofers.  They didn't back off big dynamic special effects for a second.  They remained musical when the soundtrack kicked in.  In other words, I was very impressed.  I simply don't know of any other bookshelf speaker on the market that I could confidently set to "LARGE" -and- route all LFE to for HT duties.  My wife, who generally ignores most of this stuff, said, "I thought you weren't going to install the subwoofer."
(I should note that our room is only ~14x18, larger rooms would likely begin to push excursion limits during low bass sequences.)
Kevin Haskins
I built twenty KIT61s for a museum exhibit in Florida.   Mike Knapp who runs www.hometheatertalk.com was in charge of the project.    They have one of those hydraulic platforms that shakes your ass around in the seats.   It's pretty much an amusement park ride type of display.   They have four of them with five KIT61s in each exhibit running the surround sound track.
Mike says in one of their other exhibits like this they spend over $10,000 on powered pro-audio speakers and the KIT61s walk all over them.    With the PE Cabinets you can build five of them for $1650 and I don't know of anything that would have that kind of clean output, extension and sheer balls for the same amount of cash.   In a smaller room where you get bass re-enforcement it is even more impressive as you point out.
More to come on the loudspeaker front after I get the Hypex Amps all wrapped up.    :D
Midnite Mick
You probably don't want to let out to much info Kevin but will the new loudspeaker "idea" be a timber match to the rest of the Exodus line?
Mike
Kevin Haskins
Mike
I'm doing a couple different projects.   Some that match the current lineup with the same drivers and some that are totally different.    I'm working on a high efficiency design that will be partially active and designed to run with the Exodus MCH platform.   I'm also working on a couple subwoofer projects due to the availability of drivers.
kfr01
I'm very excited to see your new speaker designs.
