Dear people, Who can tell me which preamplifier of Bryston is equivalent to the preamplifier part of B60SST? I gladly hear it. Gr., Hififreak
Hi James,Thanks.What do you think of using the combination preamp section B60SST - Bryston 14BSST?I gladly hear it. Gr., HififreakNo problem - it will work fine. Just make sure you remove the U pins from the back of the B60 to disconnect the preamp section from the power amp section.james
