0 Members and 1 Guest are viewing this topic. Read 25065 times.
This new Audio Circle software doesn't pop up a box when I have new messages and so I never notice. It's also much harder to see what is new and what I've already read.
As for not being able to hear early reflections, that's not exactly true either. You certainly can hear VERY early reflections - things such as early bounce off a console, early bounce off a TV between 2 speakers, early reflections from speakers placed close to a wall. Those things that are within say 5ms of the original signal. You can also hear late reflections - that which we call echo. It's the ones in between that are up for debate. There is some research to suggest that those are in fact beneficial - for speech intelligibility - not necessarily for music.
Quote from: 8thnerve on 22 Aug 2006, 06:55 pmMeanwhile, the wave that bounced into the corner underwent a severe comb filter by collapsing into the 90 degree angle, and now returns and is amplified by the horn shape of the corner. This wave is of much higher amplitude than the unabsorbed wave at the first reflection point would be and is also much more distorted. Since the human ear can distinguish signals only so far below the sound of highest amplitude, this first reflection is for all intents and purposes, inaudible.Nathan...based on this, could you conclude that if you treat the corner (a al a product like an Adapt Rectangle/Triangle) and reduce the amplitude of the corner amplification/distortion, then proportionally, a reflection at the first reflection point then becomes more audible? From your comment, perhaps now the highest amplitude sound gets reduced by the corner treatment, and the first reflection suddenly becomes proportionally significant?
It's not quite that simple. There is a midrange frequency band where, for a given panel thickness, 100 percent of the sound is absorbed. As you go higher in frequency the surface becomes more reflective, especially for sound arriving at an angle. At some point the waves tend to bounce off the fiberglass, like a rock skipping over water on a lake. And at lower frequencies the material absorbs less as you describe. But it's not a continuous curve.
That doesn't explain anything. According to what you just said above you use 705 rigid fiberglass. So how is that not absorption?
Also, in the graph you posted, missing is how many of each type of product was used, and also how large the room is. Got some stats?
Actually, I partly agree with that. I believe what we hear most is the skewed frequency response caused by comb filtering. The reason early reflections affect "imaging" is because the response is skewed differently at each ear. So it's probably not due to phase shift and "time smear" (whatever that is) as so many people claim, but simple frequency response differences.
Technically speaking, adding absorption into a room reduces the extra energy that lingers if it were not absorbed. The flattest response is in an anechoic chamber. Everything else is skewed compared to that.
Quote from: 8thnerve on 29 Aug 2006, 02:50 pm This new Audio Circle software doesn't pop up a box when I have new messages and so I never notice. It's also much harder to see what is new and what I've already read. FYI - you can turn on email notifications by going to Profile->Personal Message Options....
Quote from: Rob Babcock on 22 Aug 2006, 11:46 pmQuote from: 8thnerve on 22 Aug 2006, 06:33 pmListen to any small room with an adequate amount of Eighth Nerve treatments and you'll change your mind. Hey, maybe I would if you'd ever check your PMs! Any of those summer deals left? Sorry Rob. This new Audio Circle software doesn't pop up a box when I have new messages and so I never notice. It's also much harder to see what is new and what I've already read. The sale page indicates to email me and that is certainly the best way to go. I don't get PMs nearly as often. If you are having trouble reaching me via email (meaning you've sent me two emails already, and the second one said, "Hey Nathan, where are you?") then shoot me a PM (and include your email address so I can compare) to make sure your mail isn't getting lost, but that shouldn't happen, I go through ALL my spam mail to make sure I don't miss anything.At any rate, you have a PM. Best,Nathan LoyerEighth Nerve
I also want to clarify that I'm not bashing the 8th nerve product. Having absorbtion in a corner is absolutely a benefit. I've never argued any different - I just argue for something a lot thicker and larger (if you need/choose to use velocity absorbers as opposed to pressure absorbers) so it will work much deeper and yeild a more even absorbtion curve (at least we agree on one thing).
Nathan,> No energy in the room has passed through an absorptive acoustic material. <I'm with the others on this - it doesn't make sense to me. But that's okay, not everything makes sense to me. > I firmly believe that we'll be able to make a ruler flat room with no absorption very soon. <Yep, right after the perpetual motion machine and an internal combustion engine that runs on water. --Ethan
I firmly believe that we'll be able to make a ruler flat room with no absorption very soon. The only difference between the anechoic chamber and that would be that the chamber would be much lower in volume.-Nathan
Nathan,Yep, right after the perpetual motion machine and an internal combustion engine that runs on water. --Ethan
Yep, right after the perpetual motion machine and an internal combustion engine that runs on water. Laughing
John,I agree. There's a lot more to it than just frequency response. Time dependent issues many times are ignored. In my opinion, getting the decay times balanced across the spectrum is more important than the ultimate in 'flat' frequency response. This is also why a 2 channel room and a multi-channel room are set up very differently. In a 2 channel room, as much as you don't want to, the room must help you reconstruct the spatial cues of the original venue (or the simulated one).
The trick is to keep it in line based on the volume of the room and keep it relatively even across the spectrum without killing it too much and making it sound dull and lifeless
In a multi-channel room, you want a much shorter decay time (more dead) and you need the control spread throughout the space more. Why? Because you have 5 or 7 distinct channels that are recreating the ambient environment and surround field so you want less 'help' from the room.Bryan
