0 Members and 1 Guest are viewing this topic. Read 30966 times.
...I think the point might be that the cabinet can act in a way similar to an auto shock absorber on the actual movement of the cone. Hence, if the whole thing is just total "damping" you could actually drain some of the life out of the drivers...
...Seems to me the aim is not to loose energy through overdamping or weak cabinet walls but equally, not to gain resonances that weren't there in the first place...
Hi Daryl, this is interesting info. I'm no speaker designer but everything I have read suggests using approx 0.5lb of poly/Dacron/etc per cubic foot of enclosure size, generally loosely distributed throughout the enclosure. I've never seen anything recommend 100% fill.When you say "1lb/ft^3 fiberglass", do you mean to use fibreglass that has a density of 1lb/cu.ft, or do you mean to use 1lb weight of fibreglass per cu.ft. of enclosure size?
more hmmmming from me .... Is the point here that a speaker box has to be "live", has to have it's own frequency response and is actively part of the process. The other extreme would be to have something so dead that it absorbed all the energy produced by the drivers and basically killed their movement [a cast lead lined cabinet?]. Seems to me the aim is not to loose energy through overdamping or weak cabinet walls but equally, not to gain resonances that weren't there in the first place.I think it's time for an expert ... that should truly muddy the waters jules
Leaving a cabinet partially resonant has it's effect upon the time/frequency and non-linear characteristics of a speaker.Therefore it is adding new characteristics to the signal not part of it originally.
If the backwave from your drivers is completely absorbed and no sound is emmited from you cabinet walls you will be left with the original signal and it will be exactly what it is.
...a low Qts driver works best with a ported box whereas a high Qts driver can take the problem you mention better in a sealed cabinet....
First off if you are talking about a kit I would recommend you build it exactly as the plans indicate.Parts Express makes some extremely nice .75ft^3 cabinets.I would use fiberglass but I am speaking in terms of designing the cabinet with fiberglass in mind and designing the crossover from measurements taken from the actual enclosure with the fiberglass installed.Using fiberglass instead of poly would give an increase in apparent volume and lower Qm as well as Ftc.The could result in an apparent lack of bass or shrill sounding speaker.If you were designing a new crossover from new measurements you could add some series resistance and bring Qm up restoring the bass and resulting in a lower bass extension than before but with a slightly lower system sensitivity.I have been speaking of stuffed enclosures where the damping materials will be evenly filling the interior of the cabinet and not attached to enclosure walls.This method is primarily used for sealed systems and results in the most absorbtion of the backwave possible.
The speaker designer had suggested that thicker boxes were fine as long as I kept the baffle height and width the same and the internal volume the same. So, I followed this criteria, built the boxes and am currently painting them. They are glued, screwed and braced, very solid, rigid and heavy. I estimate approx 40lbs per empty box, not bad for standmounts.
To re-ask a question that I don't think you answered ... if the designer's measurements in the thinner box with 0.5lb polyfill were flat (+/- 1.5db), does this mean that there were no troublesome standing waves or reflections? If so, does it mean that a thicker box, more bracing and fibreglass (instead of polyfill) will not provide much benefit?
Finally, are you suggesting that in a sealed box, 0.5lb scattered polyfill is more effective than an equivalent amount of poly batting (0.75" thick polyfill sheets) against the sides and stapled only in each corner? I was considering using 3 sheets thick of the 0.75" poly batting on all walls, stapled just at the corners so that it is 2.25" thick everywhere except at the corners.
According to Kam Leung, the designer of the FS-888, Focus Audio had experimented with additional damping materials, including lead sheet and bituminous compounds, but found that these deadened the box so much that the resulting sound was sterile. Instead, he preferred to keep the cabinet just slightly resonant, which, he believes, helps retain the emotion and expressiveness that have become Focus Audio hallmarks...
quote Daryl:"If the backwave from your drivers is completely absorbed and no sound is emmited from you cabinet walls you will be left with the original signal and it will be exactly what it is."If the backwave from a driver is completely absorbed, then, in the case of a ported system, no sound would come out of the port. If you were literally able to absorb all the energy off the back of a driver, that driver would be unable to move at all. [edit: just to clarify this a little ... if you were to attach a small shock absorber to the back of a driver cone, it could absorb the cone energy, convert it to heat, bring the cone near to a dead stop and burn out the coil.]
The space within a cabinet is akin to a tuned spring set to a particular frequency to work in concert with the various Thiele-Small characteristics of the driver [including the drivers own Fs, frequency]. It is unavoidable that cabinets and drivers have particular resonance frequency but to suggest that... quote Daryl:"Leaving a cabinet partially resonant has it's effect upon the time/frequency and non-linear characteristics of a speaker.Therefore it is adding new characteristics to the signal not part of it originally." ... is to deny the role of box tuning! A box is a lot more than partially resonant. The design of a speaker cabinet requires the balancing [not denial of] a number of unavoidable frequency resonances in various components. A driver has an Fs. A box has a frequency Fb [related to the Fs and Qt for a given driver]. A port, if used, is tuned in relation to the box Fb.
quote Daryl, opposing the view that damping "will suck the life out of music" :"It is easy to prove it to, just take a speaker and jam it full of fiberglass and give it before/after comparison.The fiberglass will change the bass weight as well as remove resonances which means you will change the design of your filters and or cabinet there is no possible direct comparison.What is important is that you can measure that the resonances and reflections are gone and you can now design the cabinet and crossover for a even frequency balance."Sorry, I don't see your point. What you seem to be claiming here is that damping [fibreglass] is selectively able to remove nasty resonances and reflections while apparently not having any effect on desirable box frequencies.
and again to quote Daryl:"I remember someone on the MAD board built a fairly large speaker and lined it with Black Hole 5 and was suprised to find it had several standing waves."If the volume of a cabinet is wrong the solution is not damping. If, for instance, a cabinet is designed with an Fb of ~120, then the result will be poor bass response and problems with speech intelligibility. I would guess that the problem you mention from the MAD board relates not to the Black Hole material but to the cabinet resonance frequency.
