New M-130X woofers
0 Members and 1 Guest are viewing this topic. Read 7855 times.
Danny Richie
New M-130X woofers
« on: 9 Aug 2006, 02:17 am »
Hey they finally hit the numbers that I was looking for implementing the XBL^ motor structure onto the M-130 woofer.
This will not replace the standard M-130 woofers. I will continue to use and stock the standard models.
These will be new additional models made available to the DIY market and to OEM's. Now that they are approved it can still be 2 more months before they land and I have them in stock.
They are going to air mail a couple of units over so I will post some pics and have more info on them later.
See measured response and specs.  :thumb:
 "Method: Fixed-Mmd (8.32 grams)"
 "DCR mode: Fixed (5.51 ohms)"
 "Area (Sd): 95.05 sq cm"
    50.585 "Fs Hz"
     5.510 "Re Ohms"
     3.664 "Qms "
     0.460 "Qes "
     0.409 "Qts "
     0.324 "L1 mH"
     0.763 "L2 mH"
    14.194 "Vas(Sd) liters"
     8.849 "Mms(Sd) grams"
  1118.644 "Cms(Sd) æM/Newton"
     5.805 "Bl(Sd) Tesla-M"
    87.844 "SPLref(Sd) dB[Re]"
RAW
Re: New M-130X woofers
« Reply #1 on: 9 Aug 2006, 05:35 am »
Looking forward to them.
Danny Richie
« Reply #2 on: 7 Sep 2006, 09:39 pm »
Have a look at the killer samples that I got in today of the new M-130X.  :green:
See it here compared to the standard M-130.
That's the new X model on the right.  :green:
A small production run will begin shortly. I am only going to run 500 of these at a time as they are a little more expensive than the standard version. I should have them in stock in a couple of months.
Production is complete on the new M-165X and that shipment will hit the water in a few days. So I will have them soon.
See response:
M-165X parameters:
Fs              40.1152
Fs Added Mass   22.8066
Added Mass      25.0000
Diameter        132.1000
Re              5.6000
Rms             1.0990
Qms             2.7385
Qes             0.5260
Qts             0.4413
Cms             1.3183
Mms             11.9399
BL              5.6603
VAS             34.5789
dBSPL           88.3001
L 1kHz          0.8683
L 10kHz         0.3618
SD              0.0137
« Last Edit: 9 Sep 2006, 12:53 am by Danny »
Loftprojection
« Reply #3 on: 10 Sep 2006, 12:27 am »
Hummm, looks good.  Care to share with us what your plans are with those new toys?  Will they replace the original 130 in the AV kits?  If so, what do you expect will be the difference in sound quality, lower bass numbers I guess?  Thanks for those photos, fun to see them side by side...
Danny Richie
« Reply #4 on: 11 Sep 2006, 03:17 pm »
They will not replace the standard M-130 in the A/V series.
I will be working on some higher end kits with them though. You will see the first kits using them offered through Raw Acoustics and using their new ribbon.
JJK
« Reply #5 on: 12 Sep 2006, 04:22 pm »
Danny,
I have a pair of Dennis's MBOW1-3way speakers. Would it be worth it to change my M-130 drivers for the new M-130X drivers when they becom available?
John
Danny Richie
« Reply #6 on: 12 Sep 2006, 04:27 pm »
I don't think that you'll be able to do a drop in replacement without some network changes. It does work ideally in the same sized box though.
jcake5
Re: New M-130X woofers, Danny ETA is?
« Reply #7 on: 20 Jan 2007, 07:12 pm »
Hi Danny,
Do you know when the new M-130X will be available?  Also, what are you planning to do with this new driver?
Kind regards,
Eric
jcake5
« Reply #8 on: 9 Mar 2007, 11:40 pm »
Danny,
RAW has the M-130X for sale as of now.  When will you?  The RAW kit is tempting but I have my own plans for the driver.  Do you have a design ready for customers that will be released in your site?
Eric K.
A DIY type of guy vs. off the shelf type of guy!
Danny Richie
« Reply #9 on: 10 Mar 2007, 02:30 am »
The woofers are not here yet. They are on the water. When they arrive then Al's kit using them will be made available and can be ordered through Raw Acoustics.
I have made no other designs using it as of yet.
gprro
« Reply #10 on: 10 Mar 2007, 09:19 pm »
hi Danny,
you said above that the new 130x isn't a drop in for the av3's. What about the OB7? Raw said in their forum that the 130x could be a drop in for the RA8.
Danny Richie
« Reply #11 on: 11 Mar 2007, 04:01 am »
It should be a drop in for the two upper and two lower woofers on the OB-7 as well.
gprro
« Reply #12 on: 12 Mar 2007, 12:32 am »
sweet :thumb:
good to know, Whats the xmax, and can they tune a little lower than the regular 130's. I would try to get them as full range as possible.
