The PR system of the VMPS speakers is affected by gravity, mass, and the impedance/pressurization of the slot. when it is enclosed by the plate or by sitting on the floor.Each of these elements serves to "control" the performance of the PR.Placing the Sub on its side reduces the effect of gravity slightly, so you would need to "add" mass (putty).If you also remove the "slot plate" (Large flat plate that encloses the slot) then the pressurization of that chamber is reduced and a small amount of putty should be added.Small amount = ? ThanksJohn
This has been a great thread so far!I am an RM 40 w/TRT's owner, and I purchased my speakers used.How do I KNOW if I have all the putty that came with mine ?There needs to be a specific weight of Putty to "get you in the ballpark"I agree with the previous poster, Brian says 6 inches, now someone say 4 ??I think Brian should just come out and say "I use 35 grams of mortite to start with" rather then 6 inches.Mortite can stratch, and 4 inches can easily turn into 5 or even 6!Why not go by weight ?Then, to confuse things even more, John says to tune for best bass ?But I think I remember Brian saying the passive tuning on an RM 40 effects the midrange ?
This has been a great thread so far!Then, to confuse things even more, John says to tune for best bass ?But I think I remember Brian saying the passive tuning on an RM 40 effects the midrange ?
What are you "compensating" for?
This is really getting putty deep!
"Hey, we are just having some fun, putty funny, huh ?" A) Me too B) Putty much C)
