volume control
0 Members and 1 Guest are viewing this topic. Read 1612 times.
G Georgopoulos
volume control
« on: 29 Jul 2006, 12:52 am »
Hi everyone how you doin
my volume control makes my amp alittle noiser than without it
do you know of any way i can fix this
cheers
ps all contributions appreciated
JoshK
Re: volume control
« Reply #1 on: 29 Jul 2006, 12:54 am »
do you know what kind of volume control you have? sounds like a noisy pot.
G Georgopoulos
Re: volume control
« Reply #2 on: 29 Jul 2006, 12:58 am »
it is a carbon type when in middle position the noise is decreased, also the whole wiring/assembly
makes the amp noisier any ideas
thanks for your input
cheers
JoshK
Re: volume control
« Reply #3 on: 29 Jul 2006, 01:02 am »
sounds like a bad pot, needs to be replaced....from my vantage anyway...not a big deal to do.
G Georgopoulos
Re: volume control
« Reply #4 on: 29 Jul 2006, 01:07 am »
thanks joshk, do you know any better way of wiring the control and what type of cable
would be best to minimise noise pickup shielded or regular wire
JoshK
Re: volume control
« Reply #5 on: 29 Jul 2006, 01:12 am »
a noisey pot isn't about shielding or wiring, it is about degrading the contacts in the moving contact.  What amp are we discussing?  That might help, as we might be able to figure out the value of the pot and tell you which one to reorder to fix it.
G Georgopoulos
Re: volume control
« Reply #6 on: 29 Jul 2006, 01:26 am »
thanks joshk,that explains the decreased noise in the middle position, sounds like a bad pot (cheap)
doesnt it?,the amp is a class-a 15watter of mine what value do you have in mind and what type
of qood quality pot should i use,shielded cable is better for noise problems isnt it, any suggestions
on how long pot wiring should be?
Frihed91
Re: volume control
« Reply #7 on: 29 Jul 2006, 08:36 am »
I wasn't asked, but i will chime in anyway.  Take a look at the stereo attenuators on the Gold Point web page.  They are reasonably priced as quality attenuators go.  They may be too big though. Others are DACT and Shallco - higher in quality and price.
Alps used to make nice pots, but no longer!
G Georgopoulos
Re: volume control
« Reply #8 on: 6 Aug 2006, 11:26 pm »
Hi guys i changed the pot but there is still noise with it than without it
any ideas?
G Georgopoulos
Re: volume control
« Reply #9 on: 6 Aug 2006, 11:46 pm »
 :scratch:
