0 Members and 1 Guest are viewing this topic. Read 18508 times.
Looks great... Do you have a ballpark price you are shooting for?-ak
A few quick questions...1) What was updates were made to the Hypex modules themselves?
2) How big is the toroid (kVa)?
3) The layout looks fairly straightforward... are we talking novice level skills for assembly, or a bit more?
That amp looks very clean!I guess the only question I have is about that single (aluminum?) plate that the modules are attaching to. How hot would that plate get under load of say 5x UCD180 modules?
Kevin,You wrote: "One other option with the UCD400 is that I'll wire the opamp buffer for use with the 12V regulated power supply for $35 per module"Can you give us your opinion as to what sonic benefits result from the above option?Thanks
