Audio/Video Gear and Systems
(Moderators:
JohnR
Blackmore
pondering about change!!!!!
brianfosdyck
23 Jul 2006, 11:15 pm »
hello,
i have a set of 3 way technic floor speakers that are shot and i was wondering wether itd b smarter to replace just the speakers or cabinat and alll?????
Volunteer
Green Bay Packers
Re: pondering about change!!!!!
24 Jul 2006, 10:34 am »
Replace the whole speaker. Post your budget and you'll get some rec's.
brianfosdyck
Reply #2 on:
24 Jul 2006, 02:57 pm »
looking for medium quality so probably $200 for a set would be about wat id pay.
woodsyi
Volunteer
Always Look on the Bright Side of Life!
Reply #3 on:
24 Jul 2006, 03:33 pm »
Medium is such a relative term. For $200 a pair, you probably have to look at a used pair of monitors for "respectable" sound quality. You can also DIY your own from kits. Technic cabinets probably are not worth the bother to work with.
Volunteer
Green Bay Packers
Reply #4 on:
24 Jul 2006, 04:02 pm »
Quote from: brianfosdyck on 24 Jul 2006, 02:57 pm
For a book shelf try AV123's X-LS 200 plus shipping.
They will be making a floorstander of same for $300 +shipping.
LadyDog
Reply #5 on:
24 Jul 2006, 04:16 pm »
Agree with Max, av123 xl-s are very nice speakers for $200. Imagine about the best you can do for $200 new?
Other than that, as Woodsyi suggested, look for used.
Pretty good advice from the guys!
Jeff
(Moderators:
JohnR
Blackmore
