0 Members and 1 Guest are viewing this topic. Read 18747 times.
According to recent thead on AA, ASIO-4-ALL doesn't bypass KMIXER if the device is using native Windows drivers (ASIO-4-ALL crashes my computer anyway).
boead: So, what you're saying is that the SN USBTD does not support ASIO either, but it is still possible to route audio away from kmixer and to the usb audio device?
Here is what Scott Noixion has to say about his USBTD with I2C.Additional information and links on XP audio tweaking below.Number One for XP is un-mapping the USBTD from XP and the dreaded Kmixer. Example below:Go Control Panel => Sound and Audio Device => Select Hardware Tab => Select USB AudioDevice => Click Properties Button => Select Properties Tab => Select the audio device =>select "Use audio features of this device" and "Do not map through this device".Foobar is a fine playback manager, but you need to select the output device “USB AudioDac/Device” and work through the myriad of choices. When in doubt, just reset to defaultand go from there.Scott Nixon
Has PS Audio actually confirmed their DAC won't work with ASIO4ALL?
Quote from: Jon L on 3 Aug 2006, 12:52 amHas PS Audio actually confirmed their DAC won't work with ASIO4ALL?This is great info. No, they haven't officially confirmed this. Frankly, and disappointingly, they seem rather uninformed regarding what we nuts are looking for in a USB audio device.
Has anyone actually tried ASIO4ALL with Scott Nixon USB DAC and know for sure it won't work?
