SP2 makes popping noise when changing channels on cable receiver
0 Members and 1 Guest are viewing this topic. Read 19995 times.
niels
I was just wondering since there is talk about discharges, ground etc., could it be that this could help : http://new.dipolnet.cz/galvanic_isolator_signal__5-2400_mhz__R48605.htm
flom
Quote from: James Tanner
Hi,
Email me and I will send you some new software to try on the popping issue.
[email protected]
Hi James, thanks for your email & Mike's advice.
The upgrade process terminated successfully. Unfortunately, the pop issue is still remaining.
I still have my previous sp1.7 @home and I have some wife pressures to go back to it...
Fabien
  • The Demo is Everything!
    • http://www.bryston.com
Hi,
[email protected]
Fabien
Ok sorry it did not work. We will continue to investigate more options.
james
flom
james
[/quote
Hope my issue is just an exception.
Thanks again for your support James!
Fabien
