Speaker Cables
0 Members and 1 Guest are viewing this topic. Read 7872 times.
markC
Re: Speaker Cables
« Reply #20 on: 13 Jul 2006, 09:37 pm »
I believe that the benefit from twisting the + and - together is to help cancel out RF.
Antman, as far as bi-wire being better sounding, only you will know for sure with your kit in your room. From what I have read and heard, some speaks do sound better bi-wired. My Soliloquy's do. More sparkle in the top end and a more fleshed out midrange is what I hear. Little to no difference in the bottom end. Try it-you might like it!
Antman27
Re: Speaker Cables
« Reply #21 on: 14 Jul 2006, 12:14 am »
any thoughts on Better cables Silver Serpent spkr cables
mca
Re: Speaker Cables
« Reply #22 on: 14 Jul 2006, 03:51 pm »
I don't see them listed on the website, so they may not be making them anymore.
They do have the Blue Truth speaker cables on sale and they look to be well built. I can't comment on the sound, but there are some good reviews out there on them.
marvda1
  • freelance reviewer: The Sound Advocate
Re: Speaker Cables
« Reply #23 on: 14 Jul 2006, 03:53 pm »
please check out www.audioartcable.com
Antman27
Re: Speaker Cables
« Reply #24 on: 14 Jul 2006, 05:18 pm »
The  Better cables Silver Serpent spkr cables was a used set of 3 but I missed out on them -
Any thoughts on Audioquest Slate?
Re: Speaker Cables
« Reply #25 on: 14 Jul 2006, 05:26 pm »
What ever cable you buy make sure you can return them if they don't get you the better bass you are looking for.
Antman27
Re: Speaker Cables
« Reply #26 on: 14 Jul 2006, 05:30 pm »
I am looking around on usedcables audiogon & ebay for used sets so returns will be a bit tough
markC
Re: Speaker Cables
« Reply #27 on: 14 Jul 2006, 09:20 pm »
If your speaks are the one's I'm thinking of with the metal dome tweets, then I'd go for the warmest sounding cable I could find. I've heard them being driven with all solid state gear and no offence but it was like the tweets were sticking knitting needles in my ears.
Antman27
Re: Speaker Cables
« Reply #28 on: 15 Jul 2006, 02:54 am »
marvda1
Re: Speaker Cables
« Reply #29 on: 15 Jul 2006, 02:59 am »
mostly all copper cables. audio art ic-1
GHM
Re: Speaker Cables
« Reply #30 on: 15 Jul 2006, 03:27 am »
Antman27 ,
I have a pair of Better Cables BlueTruth biwire 6 ft cables laying around. I haven't used them in two years. Nothing wrong with the sound..I just don't have the biwire type speakers anymore. Last time I used them, they were plugged to a pair of Paradigm 20v3. I took the bananas off the speaker end of the cables. So now there's bananas just on the input side of the cables and bare wire on the biwire ends. You can try them if you like... No strings attached. Just hit me up and we'll work out the details.
Good luck with the hunt! :D
Antman27
Re: Speaker Cables
« Reply #31 on: 16 Jul 2006, 06:31 pm »
GHM
PM sent
Frihed91
Warm cables
« Reply #32 on: 16 Jul 2006, 10:05 pm »
Antman asked about warm cables.  My experience is that copper with Litz construction gives both warmth and detail.  Audio Note Lexus speaker cable and Moon Audio Black Dragon are two i own that are warm and detailed and have this construction.
Antman27
Re: Speaker Cables
« Reply #33 on: 26 Jul 2006, 08:18 pm »
I hate to bring this subject back up again BUT here I go
I have been trying to learn asw much as I can about speaker cables & some foks have even been so nice to let me demo some cables they were not using .
So the stuff I was looking into
Kimber 8VS
SYNERGISTIC RESEARCH Alpha Quad
gregg straley reality cables
Alpha Core MI-2 Veracity
Belden 5000 series Cable from Blue Jeans Cable
Now the next Question is what is the real deal Re Oxygen free cable
As you guys know I am looking for deeper lows & some claim that my speakers tweeters are rather harsh so want to smooth them out
 Thanks again for all your thoughts and offers
 Antman~
markC
Re: Speaker Cables
« Reply #34 on: 26 Jul 2006, 09:35 pm »
I'm certainly no expert in cable geometry, but I believe that all oxygen free copper is, is that when the insulation is applied to the copper conductor all oxygen is removed during the process, (in a vaccum). It is the oxygen trapped between the insulation and the copper that will cause the copper to oxidize. Without the presence of oxygen, oxidation, (corrosion), cannot occur.
DSK
Re: Speaker Cables
« Reply #35 on: 28 Jul 2006, 12:08 am »
Really?  I thought it was something to do with the way the copper is drawn, such that there are less oxygen bubbles/voids in the copper that can disrupt the signal flow, making it slightly less efficient and direct.   :dunno:
markC
Re: Speaker Cables
« Reply #36 on: 29 Jul 2006, 02:26 pm »
You could very well be correct. Perhaps someone that knows for sure could chime in.
john1970
Generally speaking there are three levels of Cu alloys:
1) ETP Coppeer (CDA 11000): O2 content ranges from 0.02% to 0.05% or in other terms it is 99.95 to 99.98% free from oxygen
2) OFHC Copper (CDA 10200): minimum purity of 99.95% pure (including oxygen and any other metals)
3) Certified OFHC Copper (CDA10100): minimum purityf of 99.99% pure (as #2)
The real question is is whether or not you personally can hear the difference.  The Belden 5000 series cables use ETP copper.  I use the 10 Ga Belden cables with my speakers (VMPS RM40s) and the sound is excellent.
One other point to remember:  Thicker wire (lower gauge) provides a higher overall  damping factor (and tighter bass).
Lastly, if you want to improve the bass I would recommend a good used REL or ACI sub.  Unless you are using extremely high gauge (thin wire) changing the wire will have a very small effect.
Good luck,
John
« Last Edit: 29 Jul 2006, 06:38 pm by john1970 »
Re: Speaker Cables
« Reply #38 on: 2 Aug 2006, 03:30 am »
Not taking sides on this discussion, but I believe there is one more, 6N pure. 99.999999% pure copper, oxygen free, probably custom order.
DSK
Re: Speaker Cables
« Reply #39 on: 2 Aug 2006, 06:03 am »
I understand that 6N = 99.9999%
