IA-7
lowrider
    • DIY
IA-7
« on: 4 Jul 2006, 08:34 am »
I am considering one of this to drive my 96 db broadband speakers, but I need to connect a subwoofer using high-level connection...
I hear that digital amplifiers dont support this connection, does the NuForce ?
ton1313
Re: IA-7
« Reply #1 on: 4 Jul 2006, 01:45 pm »
This Pre does have a set of line level outs that could be used to send a signal to a sub via interconnect. They were put there incase you wanted to add a pair of amps to bi-amp speakers, or if you decide to use different amps, you could use the pre side of the IA-7 by its self.
This is a great sounding unit!
lowrider
    • DIY
Re: IA-7
« Reply #2 on: 4 Jul 2006, 01:53 pm »
Thanks, but my subwoofer doesnt have xover on the low-level input, so I need to use high-level, connected to the speaker outputs...
ton1313
Re: IA-7
« Reply #3 on: 4 Jul 2006, 01:57 pm »
One additional question.
Very rarely, when turning the unit off (remote or control knob) the blue lights stay on. No sound is being produced - so unit is officially "off". To fix this situation, I have to turn off with the rear rocker switch. Any idea why & if this is harmful or not?
ton1313
Re: IA-7
« Reply #4 on: 4 Jul 2006, 01:58 pm »
If you have to use speaker level, just use some jumper wire from your speaker binding posts to the sub.
timothyharnett
Re: IA-7
« Reply #5 on: 5 Jul 2006, 01:03 pm »
I think the problem is that you can't common the earth so joining up the amp to the sub using a three pole connection won't work.
The alternative is to use two subs so that you can connect one to each side without commoning the earth.
lowrider
    • DIY
Re: IA-7
« Reply #6 on: 5 Jul 2006, 01:44 pm »
Some manufacturers even sell an accessory to connect high-level with their class D powers, otherwise you might blow them...
