Steve,Going fishing this weekend reminds me that I have one of these for a trolling motor. Can I just charge it up and use it to power Off Ramp? If I just cut the transformer off the stock PS unit, does it matter which wire goes to which terminal?
Quote from: woodsyi on 30 Jun 2006, 06:09 pmSteve,Going fishing this weekend reminds me that I have one of these for a trolling motor. Can I just charge it up and use it to power Off Ramp? If I just cut the transformer off the stock PS unit, does it matter which wire goes to which terminal?Yes, you can use this battery with Off-Ramp. The outer contact should be minus and the inside contact is plus.Steve N.
Quote from: audioengr on 30 Jun 2006, 07:31 pmQuote from: woodsyi on 30 Jun 2006, 06:09 pmSteve,Going fishing this weekend reminds me that I have one of these for a trolling motor. Can I just charge it up and use it to power Off Ramp? If I just cut the transformer off the stock PS unit, does it matter which wire goes to which terminal?Yes, you can use this battery with Off-Ramp. The outer contact should be minus and the inside contact is plus.Steve N.Steve,I looked at the cable -- which is inner and which is outer? I see one line with gray lines and one without.Thanks
It would be good to keep the wire from the battery short or solder a low impedance electrolytic across + and - right near the plug to the Off-Ramp. I like to use 3300-4700 uFd at 25V.Steve N.
Quote from: audioengr on 16 Jul 2006, 01:40 amIt would be good to keep the wire from the battery short or solder a low impedance electrolytic across + and - right near the plug to the Off-Ramp. I like to use 3300-4700 uFd at 25V.Steve N.The wire is 6 ft from off ramp to the battery. Do you mean that I should solder on a coupling cap of the value you specified between the wires at the off ramp end?
Steve,Vishay/Sprague, Nichcon, Panasonic, BC component and more. Is there a particular brand that is better suited for this task?
