LS6 v. Mini Open Baffle
0 Members and 1 Guest are viewing this topic. Read 1582 times.
klh
« on: 16 Jun 2006, 08:01 pm »
The LS6 should have higher sensitivity and more dynamics. The Mini Open Baffle has a more open sound. Is there more to it than that? If one can substitute the XBL tech speakers for the two woofers on the Mini Open Baffle (leaving the MTM component unchanged), the frequency response of the LS6 v. the Mini Open baffle would be similar.
Which way are you guys leaning?
Cacophonix
Re: LS6 v. Mini Open Baffle
« Reply #1 on: 16 Jun 2006, 08:20 pm »
Quote from: klh
This is something that i've been wondering about too. The prices of the kit versions are quite far apart though. I think there is almost a difference of around $800 between the two. So that to me is the most significant difference  :)
