Questions concerning soldering additional components
0 Members and 1 Guest are viewing this topic. Read 1376 times.
Julien43
Can someone tell me the correct way to solder components to a pre-stuffed pcb?
(another question)
If the leads of the components are too large to fit in a thru-plated holes, is there an acceptable method to attach additional components to the leads of other components?
Thanks for taking the time to read my post
markC
« Reply #1 on: 13 Jun 2006, 02:36 am »
You can solder a strand of wire to the bottom/top of the board and then solder your component to the wire strand on the other side of the board. As for component lead being too large for a plate through board  , that's a tough one. Being brave, you could enlarge the hole,(losing the plate through and do the wire strand trick to the next connection), or run a jumper wire from one side of the board to the other.
Gordy
« Reply #2 on: 13 Jun 2006, 03:25 am »
I've had excellent results enlarging existing holes by using the micro drill bits I found at a local hobby shop / model train store.  They also had a selection of micro hand drivers... just take it slow and easy and you won't disturb the pad!
MarkM
« Reply #3 on: 13 Jun 2006, 11:53 am »
Quote from: Gordy
I agree, just be careful you start with a small bit that will not grab and lift the pcb trace.  Been there...
