It's playing absolutely beautifully. The only kit-built/DIY component (well, aside from Garrard turntable plinth) in the system.
I'm experimenting with other cables besides from the Taras and experiencing significant improvement. Auditorium 23s this week, which were wonderful - natural, musical, but neutral - the sound just broadened across the spectrum. Silences becamse more silent. Surface noise on vinyl because slightly more evident but also, oddly, slightly less annoying. It also sounded, subjectively, slightly louder.
Next up: Audience AU-24s. But I have difficulty imagining cables that beat the Auditoriums, at least in this system (synergy being all, in my view).
Note: all these are thin cables. The Audioriums have a handmade cotton shield (that LOOKS handmade - I think these are built to order) that is supposed to act as an excellent dialectric. Who knows, it looks kind of cool and non-audiophile cable-ish.
Edit: I suspect my VMPS hybrid ribbon monitors are tougher to drive than their 90 dB sensitivity rating suggests. The manufacturer recommends a high current amp, whether tube or SS. The AKSA might be pushing it _just slightly_ but it could also be a room-size issue or a cables issue. I can get quite loud, but there is a sense, especially on large-scale orchestral pieces or rock music, that the amp is straining to move air on the VMPS woofers at really ear-splitting volumes. Which one likes to do sometimes.
However it's a tribute to the AKSA that this limitation is making me explore speaker cable and speaker options rather than amp options. I've been through a zillion amps and the AKSA is the most musical and troublefree amp by far. I'm sure a massive tube Conrad-Johnson Premier 4 or other such monster would slay me - also a monster NYAL, or possibly an original Harmon-Kardon Citation II. But I already have the trouble of dealing with 24 tubes in the Io Sig and its power supply, the 8 tubes in the BAT, the maintenance, the replacement parts and tubes, the RF, and finally the heat and electricity bills they all generate! None of this with the nice musical N+.
I prefer to keep my tricky little constant maintenance issues focused where they belong - in the analog (only) front end - and let the rest of the system just do its work, thank you very much.
We'll see if VMPS's new "constant directivity wave guide" mod makes a huge difference (if they ever finally get it into production for my model -- see the VMPS forum for discussion)... and if not, then it's back into the speaker world. I quite like (but haven't heard in my system) Reference 3As. I bet the AKSA would drive 'em like a dream too.
Patrick
