Line array clearance !
0 Members and 1 Guest are viewing this topic. Read 2958 times.
RAW
« on: 7 Jun 2006, 05:56 pm »
Yes we are moving on and these clearance deals are limited to a few pairs.
 Lambda and Omega limited kits.
Limited meaning no crossover parts at all this is so you can source the brand of components that you want to use for caps and inductors plus wire.
Included in the limited kits
Drivers and baffles and crossover plans only no other parts.
Omega $2640
36 WR125ST
24 Ribbons tweeters
1 CNC baffle Drivers require thick gaskets we supply
1 pre assembled cabinet 12x12x80 using 1.25" MDF
Lambda $1256.00 plus shipping
16 WR125ST
12 Ribbon tweeters
2 CNC baffles Drivers require thick gaskets we supply.
Omega
   cabinet dimensions
   Sealed tuned to 70hz
  12"W X 12"D X  80"H  using 1.25" MDF
Lambda
   cabinet dimensions
  12"W X 12"D X  60"H  using 1.25" MDF
For those interested please email.
« Last Edit: 19 May 2007, 10:07 pm by RAW »
RAW
Re: Line array clearance !
« Reply #1 on: 19 May 2007, 10:12 pm »
Bump
Added a single assembled cabinet for the Omega array
Price drop to clearance $2500.00 for the Omega array including 1 assembled cabinet 1.25" MDF plus 1 CNC baffle cabinet will need to be built
36 WR125ST
24 Ribbons tweeters
Lambda clearance $1100.00 with 2 cnc baffles no cabinets just the front baffles plus drivers
16 WR125ST
12 Ribbon tweeters
Not available anymore.
« Last Edit: 1 Jun 2007, 02:22 pm by RAW »
