Stands with HT3s
R_burke
Stands with HT3s
« on: 7 Jun 2006, 03:39 am »
Any suggestions/recommendations for stands to use with HT3s?
opnly bafld
Stands with HT3s
« Reply #1 on: 7 Jun 2006, 03:54 am »
I would just use cones.
Lin
RAW
Stands with HT3s
« Reply #2 on: 7 Jun 2006, 05:32 am »
Stands for the HT3  :wink:
Or are you asking about the HT2 and them needing stands.
The HT3 you can just add a base to the bottom as we do in all our finished speakers .
We make them flush to the front and 2" over each side.
Then add spikes if you want.
We have high end spikes but for those looking else were I really like these spikes
http://www.oregondv.com/Speaker_Stand_Spikes.htm
These you drill a hole threw the bases and put a threaded insert in from the bottom and thread the spikes threw the top.
Then if you have to move the speaker you just thread them up and move the speaker.
No need to tilt them back and then hope you do not scatch yourself or anything else with the spikes.
As well this site has loads of spike to pick from.
R_burke
Stands with HT3s
« Reply #3 on: 7 Jun 2006, 01:55 pm »
Got it, thanks
