Behringer DEQ 2496/Analogue inputs
Hipper
« on: 30 May 2006, 06:57 pm »
Is there some way of having an analogue input into the Behringer and having the signal coming out from its digital connection?
I currently have the Behringer between my CD Transport and DAC and this is how I mostly listen. The DAC has a volume control. At the moment I have an integrated amp but will soon be getting a power amp (Son of Ampzilla).
I have a turntable which I would like to listen to occassionally, so I'll get a phono stage, and then ideally I would like that to feed into the Behringer (through its analogue 'in') and then get a digital signal out to go to the DAC. This way I would have a volume control and a better DAC then that in the Behringer, plus I wouldn't have to change any connections every time I wanted to use the turntable.
Is this possible?
I have tried, using various changes in the I/O menu but can't get the signal out through a digital connection.
The alternative would be to buy an Anolgue to Digital Converter unit to sit between the phono stage and Behringer. Do such ready made units exist?
warnerwh
« Reply #1 on: 31 May 2006, 12:34 am »
The Behringer has an analogue to digital converter in it. How you use it with a second source though I don't know.  You may be able to use the outputs of the Behringer into your preamp using the dac in the Behringer which is actually pretty good.
Rich Carlson
« Reply #2 on: 31 May 2006, 10:25 am »
As long as you have set the source for the digital output (on p. 2 of the I/0 menu) to anything other than the input signal displayed in the lower left (see Figure 3.21 in your manual - this will be the main or dig. in source selected on I/O menu page 1), this should work fine.  You then use page 1 of the I/O menu to choose between "Main In" for your analog source and whichever "Dig. In" (XLR or optical) you are using for your CDP.
Hipper
« Reply #3 on: 31 May 2006, 07:40 pm »
Warner and Rich; thanks for your replies.
Armed with the knowledge that it IS possible to have an analogue input to the Behringer come out as digital, I had yet another try. It turns out that I had set up the Behringer correctly, but had not adjusted the various input and output knobs on my integrated amp properly.
Doh!  :oops:
Thanks again.
