Force Spikes
Guest
  • Guest
Force Spikes
« on: 29 May 2006, 08:21 pm »
Has anyone found a good alternative point to that offered by ACI (I HATE brass with a vengeance...and black chrome)? I'm looking for a non-brass metal connection from the Force to the steel cups offered by Sound Anchor. Ideally I'd just had 1/4"-20 cone point set screws (to fit the mount provided in the Force), but I only need four and can't find them in a package of fewer than 100. Any brushed/raw steel suggestions?
Berndt
Force Spikes
« Reply #1 on: 29 May 2006, 08:38 pm »
if you just want 4 try a local machine shop or fastener jobber, they should at least cut you 4 pcs of all thread then grind or machine a point...
