shiva or tempest?
0 Members and 2 Guests are viewing this topic. Read 7226 times.
jbandpc
shiva or tempest?
« on: 30 May 2003, 01:29 pm »
First let me say that tight, clean bass is the priority, with extension a close second. SPL is not a real concern.
If I had enough room and approval to build a 122 liter sealed cabinet, which should I choose, the Tempest (at 122 liters, Q=.707) or the Shiva (at 122 liters, Q<.577)?
Thank you for any response. I don't yet know how to interpret the information given in software.
shiva or tempest?
« Reply #1 on: 30 May 2003, 01:41 pm »
Lower Q is said to offer the "tighest" bass.  So I guess that means the Shiva.  Have you read the white papers on both alignments?  Some good information in there that may help you decide.
jbandpc
shiva or tempest?
« Reply #2 on: 30 May 2003, 02:35 pm »
I'm just not quite ready to go the shiva route because I'm not sure what I'll give up in extension.  Any thoughts on this from anybody?
shiva or tempest?
« Reply #3 on: 30 May 2003, 03:21 pm »
Have you read the white papers at the adire audio site?  They have charts showing the FR for ported, sealed, size of cabinets, etc.
I didn't find much difference in extension in a sealed cabinet between the too.  If you want max extension then go with a ported cabinet.
http://www.adireaudio.com/tech_papers/tempest_paper.htm
http://www.adireaudio.com/tech_papers/tempest_apps.htm
http://www.adireaudio.com/tech_papers/shiva_apps.htm
http://www.adireaudio.com/tech_papers/shiva_paper.htm
JohnR
shiva or tempest?
« Reply #4 on: 30 May 2003, 04:31 pm »
In that size box it's arguable that the Shiva has (very slightly) more extension (but less output)
Val
shiva or tempest?
« Reply #5 on: 31 May 2003, 01:54 pm »
I agree that you should go with Q=.577, but you should also check Adire's stock of DLP12s that were custom made for the Canadian company Mirage, I believe. With the caveat that I am no DIY expert, its specs appear to me to be a bit better than either Shiva's or Tempest's, especially fs (low) and QTS (high):
DLP12  fs=16.3Hz Qts=.400
Shiva  fs=21Hz; Qts=.390
Tempest  fs=18.8Hz; Qts=.390
I am sure Dan Wiggins will be happy to help.
Val
JohnR
shiva or tempest?
« Reply #6 on: 31 May 2003, 02:04 pm »
rosconey
shiva or tempest?
« Reply #7 on: 31 May 2003, 02:06 pm »
you might also look into going with a passive radiator if ported isnt for you.a 12 inch shiva with a 2- 15" passive radiators, saw some one did one and the specs looked awsome.
