Amps with signal sensing auto turn on
0 Members and 1 Guest are viewing this topic. Read 2801 times.
ryno
« on: 23 May 2006, 02:00 am »
I'm looking for a couple auto turn on amps. A lower powered one for a pair of bookshelves in the bedroom, and a more powerful one for a pair of full rangers connected to the TV. The emotiva BPA-1 would be great for the bookshelves, but a little spendy, and maybe an audiosource for the full range. I've had an audiosource burn out in less than a year, so I'm a little hesitant to try again.
Any other suggestions?
Thanks, Ryan
OTL
« Reply #1 on: 23 May 2006, 03:59 am »
Find a good sounding amp an leave it on all the time.  At the extreme outside this is going to cost an additional $20 bucks/yr.
Just no sense in limiting your choices to an "auto-on", unless of course your thinking green.  If that's the case, I'm exiting, staqe right.
nelamvr6
« Reply #2 on: 23 May 2006, 10:14 am »
I know that NAD makes units with auto-sense, but I've heard that this feature isn't implemented all that well.
ryno
« Reply #3 on: 23 May 2006, 02:27 pm »
I am not thinking even midfi at all, just ease of use, budget, safety, and maybe a little green.
Ryan
JoshK
« Reply #4 on: 23 May 2006, 02:34 pm »
Rod Elliot's page has some pretty straightforward kits that allow you to build a remote sensor for amps that don't have them built in.  So you won't have to limit your search.  Costs ~$50 to build.
ryno
« Reply #5 on: 24 May 2006, 02:48 am »
Thanks Josh
Cool site, but I dont think I want to put that much work into this.
Is this a crazy idea: The soft starts for hypex amps can be turned on with a switch, can I use a relay turned on with the rca video out from a TV?
ie, what kind of voltage does an rca video out have, and is there a relay that can use this?
Thanks, Ryan
JoshK
« Reply #6 on: 24 May 2006, 02:55 am »
I don't know of any ready made designs that do this.  In theory it is doable, but I am not sure it would be transparent.
ryno
« Reply #7 on: 24 May 2006, 04:12 am »
I was thinking of an auto relay where the video signal trips the relay and completes the circut to turn on the softstart.
As for transparent, I could use the monitor out from the tv, It would only be used to switch the relay. I just don't know if an RCA video signal is enough to trip the relay.
Ryan
jhenderson010759
    • http://www.innovative-dsp.com
Outlaw M200s
« Reply #8 on: 24 May 2006, 01:26 pm »
Check out the Outlaw M200s.  They support music-mode.
