0 Members and 1 Guest are viewing this topic. Read 18933 times.
Yes, the all-in-one aspect is very nice. Fits in your cabinet, computer doesn't need to be on, allows the wife and family to play "one-off" CDs just like a regular CD player (no ripping required), and allows recording your old vinyl directly to digital.Also can act as a "squeezebox" type device, as Jim as doing, but presumably that is a secondary function (since the squeezebox is cheaper).Overall easier to use, more like the CD player it replaces.
Waynethank you for posting your initial impression on the Olive. Given the limitations you mentioned, I was wondering if you have had an chance to take a look at the cambridge model server. Wonder if anyone has one for wayne to experiment on as an alternative. As someone who uses a wayne/bolder modded oppo transport every day, I would interested in what a bolder server could do. FYI sonically, the oppo overachieves everyday. A curious platform to mod yes...but the end results into my meitner dac are wonderful
FLAC isn't mentioned on the link posted. It would be good news if it is coming. I do think the point of these boxes is that they are all-in-one, so most of us will want the compression on the box.By the way, if there are any Olive owners following this thread, I would love to see answers to my separate posts concerning remote control of the Olive! (hint, hint). Those are the sort of details that are hard to figure out from spec sheets. Perhaps I'll just have to order one with the 30-day return and find out.- Eric
The remote is where I think they missed the boat. Although nicely featured, it should have had the same screen that is on the front of the unit. So you could sit in your listening chair and browse through your 500 CD's. If you have to get up to view what you are doing, it is not a whole bunch different from replacing the CD in the drive of a conventional player. However playlists and shuffle plays are an option. I found the Hard drive on my unit to be very, very quiet. The CD spinner is the noisy part. When it is recording the CD the spinning was audible. Once you remove the disc and play from the hard drive my unit was very quiet. ...
Could someone point to me a thread or threads that discuss/recommend a simple always-on networkable music server that could be used with SB2/3?Thanks.Scott.
I received a couple of the Olive Musicas over the weekend.The display is VERY small. there is no way to see what is playing more than a couple of feet away from it.
