Macro photography
0 Members and 1 Guest are viewing this topic. Read 3065 times.
jlupine
Macro photography
« on: 29 May 2003, 07:31 pm »
At the same magnification, distance, and aperture, do dedicated macro lenses have the same depth of field as normal lenses with "accessory macro lenses" attached ?
Jan
drphoto
Macro photography
« Reply #1 on: 4 Jun 2003, 03:05 am »
Interesting question. One I can't really answer on experience since I never used those macro filter things.
But my guess is that it would be the same, because we are dealing with the physics of how light is refracted through a lens system.
I would suspect the image may not be as sharp.....considering that true macro/micro lenses are designed for close up work and those attachments are cheap, but DOF.....probably the same.
Why not rent a macro and do some test?
lo mein
Re: Macro photography
« Reply #2 on: 6 Jul 2003, 01:32 am »
Quote from: jlupine
Jan
I have not worked with such device.
But I think you may loose about  2 f-stop worth of light value from the original lens.
Check with the manufacturer.
Alex
