Pioneer EX-500
0 Members and 1 Guest are viewing this topic. Read 1679 times.
Carlman
Pioneer EX-500
« on: 8 May 2006, 02:26 am »
Well, I finally bought a replacement system for my HT enjoyment.  I wanted to buy something really nice but couldn't justify it.  I had the Panasonic XR-25 which, quite frankly is mediocre at best for HT use.  I was using a Pioneer DVD player with the wrong remote... and it was just kind of disjointed and annoying... and the sound quality was kind of muddy.... and the components didn't look good under the TV, one black, and one silver.... (WAF issue) and there was some unused space because of their size.
Over time, I have upgraded from RAD Micro's to some Usher S520's and matching center for the front 3... and I bought a new sub from Merle, a 'Focal' or 'JM Labs' which is great.... The receiver was the last step.  I considered a lot of $500-$1,500 options but just couldn't get my head around why I would do that when I could use that money for other things in my main system.
So, at $250, this setup fixed everything.  I used the MCACC feature to setup the speakers.  There's no sweet spot in the room, really... My wife and I sit on separate couches, and the TV is at a 45* angle in a corner.  WAF overrides most SQ factors.  So, I put the microphone between us and hoped for the best.
The size is perfect, we have a whole new shelf to put things now.  We have 1 remote that controls most things.  And, the old system is going to work fine for the bedroom system... We can upgrade the Aiwa minisystem! woo-hoo!
The Pioneer is a significant step up in sound quality from the Panny; more impact, realism, better surround processing, everything is better.  The new DVD player is also a step up from the older DV-444 in sound and picture quality.  So, I'm happy for not much money; a good situation! :)
Just thought I'd put this out there as a consideration if you're in the same boat as me, where you want a good bang-for-the buck system... the Usher's with the Pioneer are a VERY good combo that compliment each other well.  You could put together a stellar system for around $1200.
-Carl
tschanrm
Pioneer EX-500
« Reply #1 on: 8 May 2006, 05:18 am »
Carlman,
How audible is the EX-500 fan on the back of the amp?  Is it on all the time, or does it turn on when you have the volume loud?
Carlman
Pioneer EX-500
« Reply #2 on: 8 May 2006, 12:51 pm »
Quote from: tschanrm
Carlman,
It's on all the time but I can't hear it at all.  You can tell it's running when you're head is near... I'd say it's a very quiet fan compared to most.
-C
Otis
Pioneer EX-500
« Reply #3 on: 9 May 2006, 02:49 am »
I've been using the EX-500 combo for almost a year now, and am very pleased to finally see a direct comparison between it and a Panny. My set was built in 2003, even though I bought it in the summer of 2005, so it looks like Pioneer has had a hard time clearing them out. Hmm...
Anyway,
I agree with everything Carl said about the Pioneer, it's quiet, sounds great, looks good and so on. I use mine about 95% of the time for 2-channel background listening, and with it's fine (by HT receiver standards) tuner, it's quite pleasant to use. I like the blue readout too much better than Pioneers' reliance on amber displays during the 90's.
However, for anyone considering one is that there are a couple of serious limitations worth noting -
First, its "100 watt" power rating is totally bogus. The back of the manual admits it puts out only 42 wpc at 1KHZ. Doing the math and converting the figures into the old RMS 20-20KHZ standard, it really puts out more like 30  watts into 2 channels, tops.
Secondly, there is a real lack of inputs. Including the tuner, there are only four accessable from the remote control, with another front panel input.
Speaking of the front panel of the receiver, it has only two controls, a volume and a source selector. EVERYthing else is operated from the remote, so you don't dare lose or mistreat it!  :nono:
Overall though, I'm very pleased with the Pioneer. Like Carl said, it's a nice for-the-money entry level system for those with few sources, and it comes with a free Elite-badged universal player that's a dead ringer for the old 563.  Not too bad!  8)
Otis
lvis11
Pioneer EX-500
« Reply #4 on: 11 May 2006, 07:06 pm »
i have this too...although i have not compared it to anything else..it does sound good..but lacks any real inputs....no component, hdmi etc....doesnt even convert composite to svideo....but for the sound...i felt it bested my old kenwood receiver..although i did not do side by side comparison....at $250(price i got it) very good value.
Brad
Pioneer EX-500
« Reply #5 on: 11 May 2006, 09:23 pm »
Carlman - separate couches :?:
Sounds like somebody needs to drop some coin on his wife's Mother's Day present...... :wink:
Haha.....anyway, looks like a nice setup for the price.
