Can someone explain parametic eq's to me??
0 Members and 1 Guest are viewing this topic. Read 657 times.
sts9fan
« on: 4 May 2006, 07:39 pm »
What is the difference between a parametric eq and a graphic eq? I am looking to add one to my system to flatten out the curve but I am getting myself confused. Which of the behringer units are people using? The ULTRADRIVE PRO DCX2496?? Is the feedback destroyer pro good enough? Finally is this plugged inbetween the source and amp? If someone could give me a breif rundown of how one of these guys is used I woul be grateful!!
Russell Dawkins
« Reply #1 on: 4 May 2006, 08:05 pm »
with a graphic EQ, the parameters (frequency and Q - or bandwidth) are fixed and all you can do is adjust boost or cut at the chosen frequency. Many find the graphic easier to use because the row of sliders is a graphic indication (hence the name) of the curve being applied to the signal.
With a parametric, each of these parameters can be adjusted over a wide range and with some precision, although with digital parametrics, like the Behringer, there is a limit to the resolution of the adjustments, technically, though you will find all the precision you will realistically need. Much more precise adjustments to the signal can be made.
Also, parametrics sometimes include peaking or shelving characteristics to each band for more flexibility.
They are typically installed just before the power amp(s).
Hope this helps.
sts9fan
« Reply #2 on: 5 May 2006, 03:12 am »
Thats what I was looking for . Thanks!
