Modified Jolida JD3000 mono blocs - $1995 pr.
0 Members and 1 Guest are viewing this topic. Read 1415 times.
Bill Baker
    • Musica Bella Audio
« on: 30 Apr 2006, 10:58 pm »
I have available one pair of Jolida 3000 mono blocs utilizing two 211 output tubes per channel for 200 watts.
 A quick list of upgrades:
 *All signal path resistors upgraded to Dale/Vishay 1 watt metal film
 * Grid stop and screen grid resistors replaced with Riken Ohm 1 watt resistors
 * Coupling capacitors upgraded to SoniCap Platinum Teflon pieces
 * All power supply capacitors upgraded to high valued / low ESR Panasonic pieces (x8 pieces)
 * All power supply capacitors bypassed with high voltage SoniCap Gen 1 capacitors
 * Input RCA jacks upgraded to WBT Next Gen
 * Internal signal wire is 22 awg solid silver.
 * Comes with both the original face plates and Cherry face plates as seen in the picture below.
 A while after completeing the mods, one unit would ocassionaly blow a fuse on power up. I am suspecting a bad 211 tube but have not yet had the time to order a new set. I do not know for sure if this is the problem but other also think it is a bad tube. The amps sound great and only have about 20 hours on them total.
 This is a DIY'ers dream come true.
 They will be sold as-is. These Reference 3000As sold originally for over $6k and I am letting this pair go for only $1995 + shipping.
