Lynn Olsen
0 Members and 1 Guest are viewing this topic. Read 1050 times.
Dan Banquer
Lynn Olsen
« on: 27 Apr 2006, 12:17 am »
Well folks; it looks like Lynn Olsen is at it again, and uncensored!
http://www.clarisonus.com/blog/?p=9
d.b.
Occam
Lynn Olsen
« Reply #1 on: 27 Apr 2006, 01:42 am »
Thanks Dan!
Of course you know where I went directly.... to John Atwood's article on power sources  :roll:  3 phase based rectifiers, pishtosh! With LeBlanc transformers and their variants, once you've 3 phase power you can arbitrarily go to any # phases, 2 phase [Edison's original preference for AC, which isn't balanced split phase but 2 lines 90o out of phase] up to 5, 10, 39. This is actually an active area in industrial electronics, aimed not only at minimizing ripple, but also minimizing those dreaded tripplet harmonics which put unwanted currents on the neutral, royally screw up power factor, and often cause electrical fires.
The transformers and rectification schemes used in some of the newer EDM machines is truly amazing.
And now I'll actually look at some of the more practical articles  8) .
AKSA
Lynn Olsen
« Reply #2 on: 2 May 2006, 11:28 pm »
Thanks Dan,
Lynn writes well, but is somewhat sneering, with very strong opinions.  He's no fool, but judging by his speakers and amps, loves complexity....
Hugh
JoshK
Lynn Olsen
« Reply #3 on: 2 May 2006, 11:36 pm »
I don't see his amps as that complex.  Expensive to build...hell yes (I know because I am acquiring the parts to do so)!
AKSA
Lynn Olsen
« Reply #4 on: 10 May 2006, 12:58 am »
Josh,
You are right about his amps.  Full of ITs, that's all.  It's his speakers which are complex, particularly the woodwork.....
Hugh
