0 Members and 1 Guest are viewing this topic. Read 8324 times.
I've heard actually that the mid-range ribbons used are surplus from some manufacturer, designed for use in automobiles. I could be wrong and there is probably more to the story than that. I'm sure either Brian or John will chime in.
Skynyrd: This upper bass lower midrange anemia you refer to is not an issue with my RM 40's. I like it heavy here for vocals and dynamics as it sounds more real to me. If you have the latest incarnation of the RM 40's it's your room, speaker position or other equipment. ...
And I own VMPS RM40's, MagnepanMMG's mounted atop NHT woofers, and Martin Logan Quests and they all suffer from lower midrange-upper bass anemia. I think it is the weakness/implementatin of the planar technologies.
Back to standard-driver two-way with subs!!!
.Failure modes we still see are buzzing and open diaphragm traces, caused by dislodged magnets. Freight damage has been identified as the source of most of these problems which, of course, do not show up in the course of our extensive QC. We have experienced about 80 failures of this sort out of 7000 panels in use. The only "fix" is to replace the panel..
..Please tell me about African Wild Dogs ??.
