Triode Integrates - Cayin, Manley Stingray, Antique
0 Members and 1 Guest are viewing this topic. Read 9819 times.
Frihed91
Triode mode is weak on the Stingray
« Reply #20 on: 21 Jun 2006, 07:05 pm »
The Stingray's triode mode is NOT single ended.  I think it is purely a marketing gimmick, since it does not come close to matching the pace and musicality of the UL mode.  For the money, a Rogue Cronus is a better buy, although it lacks the intoxicating punch of the Stingray.
davehg
    • http://musicserver.blogspot.com
Consider a VAC Avatar
« Reply #21 on: 21 Jun 2006, 09:26 pm »
Used they run about $2000-3000, more for the Super (which uses KT88's).  I've used an Avatar SE (EL34's) for 2 years now, which is 60w ultralinear, and 27w triode. Sound is gorgeous, not at all like a softer EL34 amp but gutsy (within its power range) and in triode, it has that SET-like appeal. Build quality is terrific and the amp is beatiful.
Preferred the Avatar SE over the Manley Stingray and the Cary SLI-80. If you can deal with less power (8-16 wpc), consider the Viva (an 845 tube).
I also owned the Passion amp, which is an ASL with better transformers and caps. Liked it alot!! They are harder to find since they are marketed primarily to Canadian buyers.  I think the ASL is decently made for the price, just not the last word in sonics.
