0 Members and 1 Guest are viewing this topic. Read 6778 times.
So don't keep us in suspense.....what is the other speaker here?
I almost think Congress should make it Illegal to sell speakers w/o level controls. ...
That's a great point about being able to adjust your speakers. I've read people claim that it's something else in the signal path. Well the room is something else in the signal path to if you ask me. The room also has a very audible effect on the sound.Level controls and their advantages far outweigh their disadvantages. I'm surprised any speaker designer would build speakers without them too. And people do spend a ton of money trying to get their speakers to sound right by changing electronics o ...
Your speakers are adjustable, arent they ?
My old B&W 801's had both midrange and tweeter controls, and one could actually tune them for best sound, in your room, with your own equipment.
I know you're familiar with Floyd Toole's work because you often have quoted it. As such, you should be aware that correcting for on-axis high frequency balance (with an adjustable pot) is a band-aid fix at best.The proper way to assure that a speaker works in a variety of acoustic environments is to design it properly. According to Toole, uniform power response is very important. Unfortunately, this aspect of speaker design is seldom discussed or addressed adequately in most commercial designs.http://www.harman.com/wp/pdf/Loudspeakers&RoomsPt2.pdf-Krull
I know you're familiar with Floyd Toole's work because you often have quoted it. As such, you should be aware that correcting for on-axis high frequency balance (with an adjustable pot) is a band-aid fix at best.-Krull
Ordering the VMPS direct drive as John Casler mentioned and using a digital equalizer like the Behringer DEQ2496 would be the way to go. I will probably be removing the adjustment pots from my RM2s in the near future as I feel they are no longer necessary with the Behringer.QuoteI almost think Congress should make it Illegal to sell speakers w/o level controls. I think Congress should make it illegal to sell speakers without a digital equalizer!
