0 Members and 1 Guest are viewing this topic. Read 6884 times.
Interesting! This says that the change in acceleration of a driver - how fast it can change position - isstrictly a function of the current through the driver. In fact, if you could make the current change infinitelyfast, then the driver would accelerate infinitely fast, and we'd have infinite transients - zero time to changebetween states. Infinite frequency response
I was just proposing possibly neglected terms. I've never studied in any depth the physics behind loudspeaker design. ...
The paper dealt with transient response - is it a mass issue (as many audiophiles believe), or is it an inductance issue (I as contend). The paper is pretty clear in its derivation - mass affects efficiency, but does NOT affect transient response. The proof is in the frequency response measurement (frequency response and transient response being related via the Fourier transform).
it might be construed that you attribute this quote to me where it is actually an extract from the paper. ""In fact, if you could make the current change infinitely fast then the driver would accelerate infinitely fast.""
Do you agree that da/dt = (BL/m)(di/dt)?
Do you agree that da/dt represents transient response?
Do you agree that inductance is inversely proportional to di/dt?
As I think about this with regard to an SPL vs. time plot, it seems that the shift for the heavier cone plot would be along the SPL axis rather than the time axis. But this would also reduce the slope of SPL vs. time - which we have defined as transient response. So, in some sense I agree with you that the timing of the musical events or ability to reproduce higher frequency is not directly influenced by mass, but in order to precisely track the SPL vs. time plot of the lighter cone driver, the heavier cone driver would have to be driven with an increased EMF and everything that goes along with that (voice coil heating, etc....).
I guess I'm starting to see that the main issue here is semantics. Is a woofer "slower" if it responds in the same time, but with less magnitude? In the strictest sense of the definition of transient response, I still say it is - but I'm not sure in the context of a real world application.
Ultimately, the deeper question is: Are the drawbacks of lower efficiency (vc heating, comlex, high power amps) preferrable to the drawbacks of taking mass out of an otherwise equivalent cone (increased flex and related distortion)? If the answer was simple, we'd all be using the same driver....
Here's one example that should completely put this all to bed. The WR125S and the FR125S drivers I designed for Creative Sound. They use the exact same cones, and even the same voice coils. The FR125S has the addition of a Faraday ring, with a corresponding reduction in inductance. The FR125S has nearly an octave wider bandwidth. This was ZERO change in moving mass - just the inductance. And bandwidth increased. ...
Mass simply scales your output; it does not affect frequency response. Hence it does not affect transient response. It can affect amplitude, but not time. Adding an inductor in series is a perfectly suitable approach; a loudspeaker is a fairly simplistic model of linear components, and with linear filter theory we can place extra inductance in series with the voice coil inductance and it will give us the same response as if the voice coil had the higher inductance. Like the FR/WR comparison. I hope the FR/WR comparison really cements this - it's about the closest thing you'll see to two identical drivers save for the inductance, and you see a very dramatic change in bandwidth. And the measurements of the driver I took with and without extra mass certainly confirms that the bandwidth was NOT affected by the extra mass! ...
