Other Stuff
Archived Circles
General Archive
How Do I Find 1st Reflection Points on the Ceiling?
0 Members and 1 Guest are viewing this topic. Read 1041 times.
gongos
6 Apr 2006, 07:51 pm »
Thanks for the help.
zybar
Volunteer
Dutch and Dutch 8C's…yes they are that good!
6 Apr 2006, 08:00 pm »
The easiet way is to have somebody hold a mirror on the ceiling while you sit at your listening position. When you can see the speaker drivers, that's the 1st reflection point.
This is of course easier if you don't have cathedral ceilings.
George
woodsyi
Volunteer
Always Look on the Bright Side of Life!
Reply #2 on:
6 Apr 2006, 08:10 pm »
George is right but a funner way is to use a LASER. Stick a mirror (borrow a compact from your spause) with double tape on the ceiling. Point the laser and see if you can hit the driver from your listening position. Under no circumstances, have your cat with you when you do this!
tvad4
Reply #3 on:
6 Apr 2006, 10:56 pm »
Silver mylar from a Party Store works the same as a mirror and is safer than glass to manipulate on a ceiling.
The methods previously described are exactly correct.
Other Stuff
Archived Circles
General Archive
