Emergency !!! Loss of squeezebox connection and need advice
0 Members and 1 Guest are viewing this topic. Read 4661 times.
John151
« Reply #20 on: 4 Apr 2006, 01:36 am »
I added a Hawking antenna to my Linksys modem (replaced one of the 2 antennas), and the signal strength increased by about 15%, which was anough to put me over the edge.  Also, it does matter how the antennas are positioned.
My cable modem is on the 2nd floor, and my SB3 is in the basement.  To make matters worse,  immediately over my SB3 is a steel I beam, a large metal air duct, and various wires and pipes.
duff138
« Reply #21 on: 4 Apr 2006, 06:07 pm »
After reading these posts I checked my signal on my wireless SB2.  Seems I'm only getting under 20%.  No drop outs or problems, but wonder what I could do to improve it.  The Linksys router is only about 12 feet from the squeezebox in the same room.
Tweaker
« Reply #22 on: 4 Apr 2006, 06:13 pm »
With the router that close to the SB you should be getting 100% signal strength.
Charles Calkins
« Reply #23 on: 4 Apr 2006, 06:15 pm »
I had a linksys router like yours but when I switched over to SBC DSL I got a Gateway 2wire wireless router with the install package. The package was one step up from entry leval. Now I have a 90% read almost all the time. Never gets below 87%.
                               Cheers
                               Charlie
duff138
« Reply #24 on: 4 Apr 2006, 07:00 pm »
Quote from: Tweaker
that's why I'm wondering what could be the problem.  Anything I should check?
Rashiki
« Reply #25 on: 4 Apr 2006, 07:34 pm »
Could be interference from another wireless network. Try changing the channel on which your router operates.
 -Rob
Tweaker
« Reply #26 on: 4 Apr 2006, 08:01 pm »
Anything blocking the "view" of the SB? Other than that I can't think of what the problem could be other than what has already been suggested. (changing channels).
duff138
« Reply #27 on: 4 Apr 2006, 10:26 pm »
Quote from: Tweaker
How do I do change channels?
duff138
« Reply #28 on: 4 Apr 2006, 11:49 pm »
Quote from: duff138
Quote from: Tweaker
figured this out, accidently hit some SES button instead of save changes.  Need to figure out how to solve this problem now.   :oops:
