0 Members and 1 Guest are viewing this topic. Read 48262 times.
It is absolutely beautiful. Can the speaker be wall mounted? If someone wanted it for a HT, do you think it would be best to get all the same?
Quote from: EProvenzanoHi Rick,Does Scan Speak make an 8" version of that driver?If so, do you think it would mate well with the Neo3 in a MTM?ThanksNo 8" version is available. Why not do a MTM with the 7" and Neo3?
rick, have you looked into the usher drivers?
Is $1295 for a completed pair? How much for a kit?Thanks
Along those same lines...What extension is possible from the 7" drivers, MTM? I don't have any issue with a large box, so let me know what the maximum bass extension would be, in a big ported box. Perhaps a floor standing MTM, with lots of depth and hight, while maintaining a minimalist baffle width.Thanks Rick.
hello rick,can you get this in a sealed cabinet? any price difference? can they be built in the parts express cabinets? thanks, drmike
Again, long winded...I apologize
The speakers just arrived via UPS. Kudos to Rick for double boxing as one speaker arrived with a hole and damage to the outer box. The sanctity of the inner box appears unbreached. Set up, unfortunately, will not occur until later this evening.
