Bella x-overs for Essence AV Series
0 Members and 1 Guest are viewing this topic. Read 3942 times.
Bill Baker
    • Musica Bella Audio
« on: 20 Mar 2006, 08:26 pm »
Greetings everyone,
 I have been receiving quite a few inquiries about providing Bella version crossovers to those interested in the Essence AV Series kits.
 For a limited time, I will be making available complete, fully assembled crossovers to purchasers of the Essence AV loudspeakers. These will be available as fully assembled units only.
 Pricing is $425 for both the Essence I & II
 Pricing is $700 for external crossovers.
These will use Eichmann Cable pods for both the input and output and will assembled allowing bi-wire configuration. At no additional charge, our custom umbilical cord using either standard binding post or Speak-On connectors will be supplied. The crossovers will be assembled in custom aluminum chassis as shown below.
 Bybee options are also available.
Bill Baker
« Reply #1 on: 18 May 2006, 01:54 pm »
For those who have inquired on obtaining Bella crossovers for the Essence/Presence loudspeakers, the special pricing of $425 will end June 1st.
 The restail cost (just for parts) for a consumer to build these crosovers is approximately $475 pr.
 Keep in mind these crossover can be used with the on-wall / in-wall versions as well.
 After June 1st. the cost for fully assembled Bella 1 and 2 crossovers will be $500 pr.
mixsit
« Reply #2 on: 18 May 2006, 05:01 pm »
Could you explain to me what this system is please? (I don't see it on your site.) Also, I've seen references to bi-amping in some of the SP posts..?
Wayne Smith
Bill Baker
« Reply #3 on: 18 May 2006, 05:14 pm »
 I am not sure I completey understand your questions. If, by system, you mean the Bella Loudspeakers, they cane be found here:
http://www.responseaudio.com/bellaSPAV1.htm
 If you are speaking of the SP Tech Essence / Presence loudspeakers, they are here:
http://www.responseaudio.com/SP%20Tech.htm
 Please keep in touch if you have any further questions, comments or concerns.
mixsit
« Reply #4 on: 18 May 2006, 05:32 pm »
The external cross overs?
Wayne
Bill Baker
« Reply #5 on: 18 May 2006, 05:47 pm »
 This is simply the crossovers built into seperate outboard chassis. One per speaker. For the Bella speakers the cord connecting the speakers and crossovers use Speak-on connectors. For units built for the SP versions, I use Speak-on connectors at the crossovers with banana plugs at the speaker end.
 The picture in the first post shows one of the extrenal crossovers used in my Bella SP/AV-2. There are more pictures on the Bella 2 webpage.
Carl V
« Reply #6 on: 18 May 2006, 08:12 pm »
How does the same XO...topology & parts function for both
a 2Pi & a 4Pi enviornment?  Does your XO incorporate BSC?
Bill Baker
« Reply #7 on: 18 May 2006, 09:53 pm »
 Hi Carl, you are absolutely correct. Yes, the Bella speakers (crossovers) do have the BSC incorperated into them. The cossovers are not the same as the on-wall versions. What I should have posted was that we can also build the Bella on-wall version of the crossover. I do have this schematic as well.
 The pricing is the same for either design.
 Sorry about the confusion.
 I am coming out with Bella on-wall as well as I will be working on some HT marketing locally. I feel the on-walls will be more to the liking of those who do not want an abtrusive speaker in their living room but do want quality sound for both HT and 2-channel music. I am not a subwoofer fan but obviously one is needed with the on-wall / in-wall versions.
Carl V
« Reply #8 on: 19 May 2006, 01:42 am »
Yowza....After seeing Bob posting a picute of his Onwall Concert Presense speaker I can see how this will be a very welcome option.
Flat panel screen flanked by a 5-6" deep AV2... if you splurge with
the High Gloss front..flush mount the drivers & paint the Frame black
It should be quite nice.
Carl V
« Reply #9 on: 19 May 2006, 01:44 am »
Gotcha...I understand now.  I was just curious.
Thanks again for your help & assistance.
Bill Baker
« Reply #10 on: 19 May 2006, 01:49 am »
 Hi Carl, actually the inquiries I have been receiving have been for a a full wrap around grill with solid hardwood top and bottom plates. Should look qite good boarding a nice plasma or projector screen. Not everyone want a big loudspeaker taking up a lot of room. I am shooting for the same Bella quality sound that will integrate into both HT and two channel enthusiast. The Bella sub is being design to compliment these speakers.
Bill Baker
« Reply #11 on: 20 May 2006, 02:46 am »
if you splurge with the High Gloss front..flush mount the drivers & paint the Frame black It should be quite nice.
 Carl, all of the Bella speakers will have countersunk drivers with black frames regarless of the finish style choosen.
