noah,
I guess the confusion is due to a couple of issues. First, it's most likely due to our definition of controlled directivity and beam width. I guess I've sort of mixed definitions in the past and haven't been clear. I should know better, I harp on this stuff all the time - let alone come up with my own definitions. So if I've confused or mislead you or anyone else, I apologize. It's totally my fault.
For what it's worth, my thoughts have been that most folks aren't interested in the "standard" definition of beam width. Who cares what angle the speaker exhibits a -6dB reduction in amplitude across the board? Nobody typically listens at such an angle anyway. My definition has been to describe at what frequency and angle the system exhibits a -6dB roll off of the highest frequencies. At greater angles yet the waveguide does provide a level of true constant directivity, but again - who cares?
Although our waveguides do exhibit what would be termed a classical "constant directivity" at angles beyond +/- 45 degrees, it is over a considerably narrower range than the span of frequencies outlined above (i.e., - the -6dB @ 10kHz spec). Actually, I need to go back and change the spec because the CD performance only goes out to about 5kHz and the angle is more like +/-60 degrees.
Thanks for calling me on it, I've never concerned myself too much with the whole issue as most folks don't have a very deep understanding of all the technical parameters - let alone seem to care. You are the first person to ever seem to be interested in such details and are the first to catch me not having my "ducks in a row" in a technical spec. It's good that someone comes along once in a while and challenges you - keeps you honest. Although, I will say we certainly weren't intentionally trying to deceive anyone.
In defense, I will say that we've claimed "controlled and constant dispersion" - not actual constant directivity. (I know, sounds like a play on words.) You can see from the graphs that this is pretty much true at angles up to 45 degrees and out to (what should show) 10kHz. It may not be true "constant directivity" but compare those graphs to any traditional 2-way speaker and you'll understand my thinking.
Falling short of true constant directivity is mainly because of two things. First, as you can see from our graphs the highs have a tendency to continue rolling off at lower frequencies as the angle increases. That's because of the throat depth in the immediate vicinity of the tweeter. We had to make the taper of it such that we get the loading we needed for L.F. extension to 600Hz. That, by default, limits H.F. extension at increasing angles off-axis.
The other is because of the shallowness of the waveguide. It simply is not deep enough to narrow directivity at smaller angles off-axis. Beyond +/- 45 degrees you start to see the effect of constant directivity much more dramatically, but the last couple of octaves are pretty attenuated.
The fact is that our waveguide is a bit of a "mixed" bag of performance specifications. It has CD properties, but it is not a true constant directivity waveguide - and as I said, I've never claimed that it was - at least not in the classic definition of the word. To get that you need a monster of a horn like Geddes is using.
Although true CD performance certainly has its advantages in many applications, it also has some pretty serious drawbacks as well. Reference my comments in the previous post regarding time delay issues, for one. With such a deep horn (OK, "waveguide") you're never going to get anything resembling time alignment. More than anything else, transient response ( I prefer "envelope" response) suffers greatly from failure to achieve reasonable time alignment and is far more important than dispersion - at least for high resolution audio anyway. If you're designing a PA system, that may be another story.
The other main issue is as stated above as well - SIZE! Look at the thing Gedddes has built. It's a monster! How many folks have room in their home for something that big? And as a near field monitor? - ain't gonna happen.
So...we don't really offer true constant directivity, or at least not over a very wide band - and to be honest, I don't think anybody really cares. It's simply not as important in a smaller room setting such as is found in most homes and studios, for which our stuff was designed. Our waveguide does improve and control dispersion to a great degree though, and it offers a host of other advantages besides - and it won't take up half the room either! I think the positives more than justify it's use and will be perceived by most to offer tremendous value, irrespective of the whole CD issue.
I hope I cleared things up this time. I also hope you're happy now that you've managed to thoroughly humiliate me before my audience.
That's the worst part about vanity - it never lasts.
-Bob
